Forum > Bazar - autohifi > P: Zesik Kenwood KAC-PS100 2x100W
 o Navštíveno 2475x o
o 12.06.2013, 21:14 | tappaja
300w bridged maximum output.
Continuous power 50w x 2 into 4 ohms at less than 0.05% THD (20hz - 20khz).
75w x 2 into 2 ohms atv less than 0.5% THD (1kHz).
150w bridged into 4 ohms (1 kHz).
Large capacity, stabilised parallel DC-DC converter power supply with pulse width modulation and 4 power MOS-FETs.
Balanced input isolation circuit for ultra low noise internal signal transmission free of ground noise.
High quality differential drive push-pull amplifier.
Built in 80Hz high and low pass filters: low pass filter for sub woofer connection with bridged output.
Built in 18db/oct low pass filter and v12db/oct high pass filter.
RCA line output terminals for in-line multi amp system.
Tri-mode operation can drive 1,2 or 3 speakers.
2 way operation mode selection: stereo L+R.
Variable input sensitivity to match source unit.
PWM regulated power supply.
Heavy duty gold plated power and speaker terminals.
Gold plated RCA line input/output terminals.
Protection indicator.
Frequency response 5Hz - 50kHz -3db
Input sensitivity 0.3v - 5v
Dimensions (W x H x D) 297 x 56 x 240mm.
Cena? 900Kc?
foto k příspěvku  od tappaja
o 12.06.2013, 21:16 | tappaja
o 13.06.2013, 09:46 | koren
"PS" je top řada od kenw - hezká cena
nějaký foto [ Link ]
o 13.06.2013, 15:57 | carelectronic
Beru ho,zabal ho a pošli na dobírku.
o 13.06.2013, 16:05 | tappaja
Zesik lezi v Lovosicich, na dobirku to neposle. Z Teplic to mas kousicek, co ty na to?
o 13.06.2013, 16:20 | carelectronic
Tak jo,je to přes kopec,dej mi na něj telefonní kontakt a zítra není problém si pro něj zajet.
o 13.06.2013, 18:24 | tappaja
725 80 58 70 Svata
Diky!
o 13.06.2013, 21:23 | carelectronic
Volal jsem mu,telefon nikdo nezvedá,zkusím zítra.
o 13.06.2013, 22:03 | tappaja
Zkus zejtra, to je na nej pozde, maka 12ky...
o 13.06.2013, 22:33 | carelectronic
OK,to jsem za mlada taky makal...
o 14.06.2013, 14:25 | carelectronic
Prodáno,resp.koupeno :-)
o 14.06.2013, 23:01 | tappaja
super!
Stránka vygenerována za 0.4412 sekund.
